Hot deal for under 400!! please give me some feedback ASAP
HHBach
Case:
http://www.techonweb.com/products/productdetail.aspx?id=A01VCN&src=PG
PSU: rosewill 500w with optical drive combo
http://www.newegg.com/Product/Produ...SubCategory=58&SortField=0&PageSize=10&page=1
MOBO and CPU combo :
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138105
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103289
Fan:
help me pick one out?
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
HDD: Seagate Barracuda
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
I already have keyboard, mouse, XP sp2 disk, monitor, and oboard graphic. please provide some feedbacks ASAP, I have a feeling this deal won't last.
it's going to used for some mid-end gaming/ but I might decide to upgrade to a graphic card later on.
What gpu do you have, I'm guessing you currently have one you'll be installing since you don't have one listed above?
I'm planning on using the onboard video. I think it should be powerful enough to do the kind of gaming i'll be doing. Afterall, it is an HD3200. If it's not, my backup plan is to get a 8800gt, but this set up should do the job for now.
Onboard will be more than enough. I ran an HD2600 for a while and it played everything on med-high. It'll definitely be worth it to upgrade to an 8800GT though, tiz an amazing little beast.
What kind of gaming is that? The onboard is decent, but don't count on playing any new FPS.
ahaha, I'm a little embarrass to say, but I'm hoping to play some CS:S on this board with an acceptable amount of FPS.
Well, TBH I have no idea how that'll work... do some google searching for "HD3200 CSS" and see what you find out. I doubt you'll get very good fps... but idk.
And don't be embarrassed, I play that game a couple times a week :).
