need some help with hardware for my new PC
computerbuild
iam building a new pc and need some help on hardware use.
this is what i put together so far.
Antec 300 case
Intel Core 2 Quad Q9550
Asus P5Q-E Green Motherboard - Intel P45, Socket 775, ATX, Audio, PCI Express 2.0, S/PDIF, Dual Gigabit LAN, Firewire, USB 2.0, eSATA, RAID
OCZ Dual Channel Platinum 4096MB PC8500 DDR2 1066MHz Memory
Diamond Radeon HD 3850 Video Card - Viper, 512MB GDDR3, PCI Express 2.0, CrossFireX Ready, (Dual Link) Dual DVI, HDTV, HDMI Support, Full 1080p
ZEROtherm / Butterfly BTF90 / Socket 775/754/939/AM2 / Copper Base / Heatpipes / CPU Cooler
3 - Seagate Barracuda 7200.10 320GB Hard Drive - 7200, 16MB, SATA-300
for a raid config.
OCZ / StealthXStream / 600-Watt / ATX / 120mm Fan / SATA-Ready / PCI-e Ready / Active PFC / Power Supply
would it be good to get ddr3 1333mhz or will it be a waste (if its needed or not i just want to know if there will be any difference at all)?
the power supply i got has 2 pci-e power plugs but doesnt say its fire cross ready, is that ok?
thanks
you should probably stay away from ddr3 until price drops, especially since ddr2 is like 4gb for less than $100
Go with the new ati series such as the 4850 or 4870.
iam kind of at my budject limit and i dont need the best card as i dont play those hight powered games and if i will need better graphics in a year or two ill be able the add another 3850 or get a 4870 for really cheap by then.
