Little assistance here
patrickv
Hey guys for some reason my msconfig does not load.
The registry path is ok it points to C:\windows\pchealth\helpctr\binaries
then msconfig.
Msconfig.exe is there in that folder but it does not launch when i go to run...
what causes this ?
:mad:
I had the same thing after a virus infected the shiznits outta my computer. All i did was download:
http://www.perfectdrivers.com/howto/msconfig.html
I also lost my regedit...and my device manager thing. A reformat+reboot fixed everything.
If you want i can upload my msconfig file for u.
ive seen various replies on google, but replacing msconfig in my case does not work, it gives the same error. my device manager is ok.
I'm not to format this.. any other ideas
Download the msconfig i uploaded (mine tha bestest :P).
Extract it in the root(???) of a drive. like:
Code:
C:\MsConfig.exe
Next best thing..no?
Just like i mentioned in another thread by you...did you really expect an answer :P
Come on bro....you're slipping!!! Jking :)
Oh that's BS. I tried the root folder thing, it works perfectly!
Thanks for the kind reply.I see CF has grown to be a mediocre recently.
Here is my log for whoever wants to help
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\igfxtray.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\system32\igfxpers.exe
C:\Program Files\Eset\nod32kui.exe
C:\Program Files\VMware\VMware Workstation\vmware-tray.exe
C:\Program Files\VMware\VMware Workstation\hqtray.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe
C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe
C:\Program Files\MSN Messenger\MsnMsgr.Exe
C:\Program Files\Common Files\Ahead\lib\NMBgMonitor.exe
C:\Program Files\CapTrue\captrue.exe
C:\Program Files\Microsoft Firewall Client 2004\FwcMgmt.exe
C:\Program Files\Bonjour\mDNSResponder.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\mdm.exe
C:\Program Files\Eset\nod32krn.exe
c:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
C:\Program Files\VMware\VMware Workstation\vmware-authd.exe
C:\Program Files\Common Files\VMware\VMware Virtual Image Editing\vmount2.exe
C:\WINDOWS\system32\vmnat.exe
C:\WINDOWS\system32\vmnetdhcp.exe
C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
C:\Program Files\BPFTP Server\bpftpserver.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Documents and Settings\pvalmont\Desktop\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,AutoConfigURL = http://seygovisa:8080/array.dll?Get.Routing.Script
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyServer = seygovisa:8080
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: Groove GFS Browser Helper - {72853161-30C5-4D22-B7F9-0BBC1D38A37E} - C:\PROGRA~1\MICROS~3\Office12\GRA8E1~1.DLL
O2 - BHO: (no name) - {7E853D72-626A-48EC-A868-BA8D5E23E045} - (no file)
O2 - BHO: Windows Live Sign-in Helper - {9030D464-4C02-4ABF-8ECC-5164760863C6} - C:\Program Files\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: PDFCreator Toolbar Helper - {C451C08A-EC37-45DF-AAAD-18B51AB5E837} - C:\Program Files\PDFCreator Toolbar\v3.3.0.1\PDFCreator_Toolbar.dll
O2 - BHO: FlashFXP Helper for Internet Explorer - {E5A1691B-D188-4419-AD02-90002030B8EE} - C:\PROGRA~1\FlashFXP\IEFlash.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: PDFCreator Toolbar - {31CF9EBE-5755-4A1D-AC25-2834D952D9B4} - C:\Program Files\PDFCreator Toolbar\v3.3.0.1\PDFCreator_Toolbar.dll
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [vmware-tray] C:\Program Files\VMware\VMware Workstation\vmware-tray.exe
O4 - HKLM\..\Run: [VMware hqtray] "C:\Program Files\VMware\VMware Workstation\hqtray.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [GrooveMonitor] "C:\Program Files\Microsoft Office\Office12\GrooveMonitor.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKLM\..\Run: [] C:\WINDOWS\system\KEYBOARD.exe
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Ahead\lib\NMBgMonitor.exe"
O4 - HKCU\..\Run: [CapTrue] C:\Program Files\CapTrue\captrue.exe
O4 - Global Startup: Adobe Acrobat Speed Launcher.lnk = ?
O4 - Global Startup: Adobe Acrobat Synchronizer.lnk = C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AdobeCollabSync.exe
O4 - Global Startup: Microsoft Firewall Client Management.lnk = C:\Program Files\Microsoft Firewall Client 2004\FwcMgmt.exe
O8 - Extra context menu item: Append to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~3\Office12\ONBttnIE.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\Office12\REFIEBAR.DLL
O10 - Unknown file in Winsock LSP: c:\program files\microsoft firewall client 2004\fwcwsp.dll
O10 - Unknown file in Winsock LSP: c:\program files\bonjour\mdnsnsp.dll
O11 - Options group: [INTERNATIONAL] International*
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain = ad.gov.sc
O17 - HKLM\Software\..\Telephony: DomainName = ad.gov.sc
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain = ad.gov.sc
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: Domain = ad.gov.sc
O18 - Protocol: grooveLocalGWS - {88FED34C-F0CA-4636-A375-3CB6248B04CD} - C:\PROGRA~1\MICROS~3\Office12\GR99D3~1.DLL
O18 - Protocol: livecall - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Protocol: ms-help - {314111C7-A502-11D2-BBCA-00C04F8EC294} - C:\Program Files\Common Files\Microsoft Shared\Help\hxds.dll
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - C:\PROGRA~1\MSNMES~1\MSGRAP~1.DLL
O18 - Filter hijack: text/xml - {807563E5-5146-11D5-A672-00B0D022E945} - C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL
O20 - Winlogon Notify: igfxcui - C:\WINDOWS\SYSTEM32\igfxdev.dll
O21 - SSODL: WPDShServiceObj - {AAA288BA-9A4C-45B0-95D7-94D524869DB5} - C:\WINDOWS\system32\WPDShServiceObj.dll
O23 - Service: ##Id_String1.6844F930_1628_4223_B5CC_5BB94B879762## (Bonjour Service) - Apple Computer, Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe
O23 - Service: Protexis Licensing V2 (PSI_SVC_2) - Protexis Inc. - c:\Program Files\Common Files\Protexis\License Service\PsiService_2.exe
O23 - Service: VMware Agent Service (ufad-ws60) - Unknown owner - C:\Program Files\VMware\VMware Workstation\vmware-ufad.exe" -d "C:\Program Files\VMware\VMware Workstation\\" -s ufad-p2v.xml (file missing)
O23 - Service: VMware Authorization Service (VMAuthdService) - VMware, Inc. - C:\Program Files\VMware\VMware Workstation\vmware-authd.exe
O23 - Service: VMware DHCP Service (VMnetDHCP) - VMware, Inc. - C:\WINDOWS\system32\vmnetdhcp.exe
O23 - Service: VMware Virtual Mount Manager Extended (vmount2) - VMware, Inc. - C:\Program Files\Common Files\VMware\VMware Virtual Image Editing\vmount2.exe
O23 - Service: VMware NAT Service - VMware, Inc. - C:\WINDOWS\system32\vmnat.exe
Ahahah. That's because I wasn't online for weeks :D
by the way, anything new happened that I should know about?
true :o
otherwise this thread would have been solved within minutes...
anything new ? hmmm not that i know of !! you can check my thread here
it's not a big issue but i like doing my stuff on my computer :o
