2 monitors and a tv
pokethesmot
how do i set this up so far i can only run eather 1 monitor and a TV or 2 monitors and no tv i have all the hookups to run them all at the same time it just wont let me it makes me choose witch 2 i want to run it looks like this can some one help me out
i have the ATI Radeon HD 2600 XT
so basically for me to use all thee ima need another card....can i just use a cheep pci card for like my stats monitor....so basically will a pciE graphics card work along side a regular pci graphics card
Nope, you can only use 2 graphics cards if they are the same and in crossfire or sli because they are actually acting as one card. And you can't mix and match nvidia and ati cards either.
I dont think that is true, I think I read (on this forum somewhere) that you can have more than 1 Graphics card running to allow for multiple monitors...they dont have to be in SLi Or Crossfire...
An example thread..
http://www.computerforum.com/121462-three-monitors.html
there you will see that several people said that you can more than 2 monitors off different cards without Sli Or xfire.
An example thread..
I didn't know that, thanks for fixing that.
So, with that said you should get some cheap ATI pci card and you should be set.
An example thread..
That's true, You can use a card in a PCI-e slot and a card in a PCI slot and run monitors of both of 'em.
Yea, it probably won't do any amazing resolutions or anything. But you could find yourself a very cheap PCI card (as others have said) and run the TV from that. If you're simply running S-Video you're not going to need high res. nor would it really make a difference.
