chibicitiberiu
Well, here is the download link: http://rapidshare.com/files/145183171/CTA_8_OS.rar.html
It is under construction right now and i need some help.
What exactly is this project:
I'm trying to create a 'simulation' of an operating system using just powerpoint and design tools.
What kind of help I need:
* Logos. I need logos for all items in the menus, user files and so on. If there is anyone here who can provide me with logos i would be happy
* Ideas on how to make it better, or adding features. It is still under constructions and it's going to be pretty cool i think. The 7th version (this is version 8) had some cool features, but many missing logos, and that kind of stuff.
* What folders should i make in these 'drives' i put in the computer (the link is broken if you try to open it in slide show mode... forgot to fix that before uploading to rapidshare
, it is on slide #11)
What features I thought about:
* a simple text editor using controls
* a media player
* a document viewer for viewing office and pdf files
Other notes:
* the file is compressed in .rar format, just extract wherever you want
* opening the file is made with the file 'main.pptx' under the 'system' folder
* you need Microsoft PowerPoint 2007, not working under office.org, or older versions of Ms. PowerPoint.
* after opening press F5 to view it as a slideshow
* the Applications menu is not created yet, so nothing will be displayed if you click it.
* the archive does not contain any .exe files, just a presentation and a couple of images
So waiting for your suggestions and opinions
* a media player
Other notes:
