big case wanted!!
funkysnair
ill pay up to £300 for a good size case....
what i want is a case thats big enough to put a tripple rad in there with 2water pumps and maybe another dual rad if its possible?
(if its not possible to mount the second rad inside i could mount it out side on the back of case)
anyone got any ideas?
was looking at this one but its very expensive and i would have to buy the extra part to fit the rad in the top
http://uk.youtube.com/watch?v=cl3AoQA7ga8
i am going to use red cold cathodes with some uv lights and some red liquid coolant so i want a side window aswell to be able to see the blood red coolant pumping round!!
thanx dude
Check out the XCLIO 1000 Black, a friend of mine has it and it's the biggest case I've ever seen:) kinda expensive but if you need big...this is BIG! he has an normal ATX motherboard and 8800GT in SLI and it looks tiny in there!
Thermaltake armour plus
I have one, it is cavernous. I had to modify my desk to fit the case under it. It is tall and long.
"The Thermaltake Armor Plus Steel Full Tower Case with Side Panel Window is a massive case with seven 5.25" drive bays, seven internal 3.5" drive bays and ten expansion slots - easily handling quad-graphics card solutions! This solid case is designed with the extreme builder in mind - everything is designed for easy installation and plenty of room."
http://www.frozencpu.com/products/6...r_Case_Side_Panel_Window_Black_VH6000BWS.html
1+ for mountain mods
if you want a p80 though, dont get the crossfire version and save your self some money and a tacky mod job
couldnt be bothered mate!! honestly-! i takes soo much time to modify cases when you dont know what yer doin!
and i dont lol
fair enough,i like that cube one though looks like there plenty of room for just about anything in there lol.
lol some guy on another forum is going about 4 loops in one of the ascensions, hes also getting a pedestal, so hes gunna have like 10 rads i total :P
yeh i agree-was looking at one on ebay and it was well modified but extremely expensive.....
im gonna weigh up my options here cos i dont want a case that everyone has-like the antec 900
antec 1200 is the best imo... has a huge exhaust fan on top and mounts the psu on the bottom, along with like five 120mm fans all over the place.
i got the antec 900 at the min but i want something different and a bit more liquid cooling friendly, i know omega has his antec1200 liquid cooled but he has his rad mounted on the rear and i want to try mount it inside without too much modding needed
