ATI Radeon 4850 to VGA
homers_odessa
Hi all
Just a quick question that I have not seen answered (specifically) anywhere else. I have just bought a new system with the 4850 as my graphics card, however my existing monitior only has 15 pin VGA input. I take it I can use a DVI - VGA cable to use my existing monitor with this card?
Yes just get one of these.
DVI to VGA Adapter.
it came with my HD 4850.
Cheers, so does that have a digital to analogue converter within it, or can DVI output a analogue signal? Sorry just dont know that much about DVI, thought it was purely digital and VGA analogue and so would not be compatible with a simple adapter.
Anyway thanks very much for the advice so far, getting the system put together so will make sure they provide the adapter provided with the card.
Schweet... Enjoy your new computer! If you can, put your specs in your signature, it'll make it easier for us to help you in the future if we know what's in your computer.
__________________
kornowski - how do you update your signature?
