What does your computer desk look like???
PHATSPEED7x
Just bought a new one from walmart. This one has much more room than my old one.
lol, my desk is one of those ones you'd see at like a catering event 3x1.5 meters, and it has 2 pcs on it with 3 monitors, 2 for the main pc, and 1 for the other one lol, and yes I do use both.
i had one basically exactly the same except that instead of a shelf on the bottom, it was empty where you'd put your tower but i had to throw mine away because it was unsteady and i needed more room :] so here's mine. Oh yeah and my old one was blue :]
Before:
after:
I tired setup my desktop, but the big CRT monitor took up too much space. The laptop works much better. I need to get a LCD monitor then I can setup the desktop.
Then again I might just keep the laptop on it. It works, it's simple, and the hardware is alot better than my old desktop.
Depends on what one. I just know I couldn't live with a res of less then 1920x1200 for my desktop.
I can sell you this one when I upgrade to the 30 inch screen...
