There's the Tri Cores, which are about £75, I think. I wouldn't even entertain looking at those!
75 punds sounds a little off to me, at that price you're right but I've seen those being sold at way better prices here in Australia (where prices on computer stuff are sometimes quite screwed in the head), not to mention that the shop where I looked them up ridiculously overprices some of their products ($90 for a pentium dual-core WTF?????).
Anyways, providing you can find those things at decent prices, I can't see why you would not go for a tri-core, those are generally clocked higher than Phenom Quads (well the ones I've seen are, anyways), so they would be better for gaming, and the extra core over you current dual-core will be an improvement. Tri-cores are specifically for people who want to upgrade but who can't afford a quad-core, they offer better efficiency and multitasking capabilities over current dual-core Athlons.
If you decide to get a tri-core, make sure that you get a B3 stepping or newer (the older steppings had a nasty bug that can cause lock-up under certain circumstances, and the fix can reduce the performance up to [sometimes even more than] 20% in games). Also, I would recommend you get the 2.4GHz version at least, as the extra clockspeed of the X2 5000+ partially makes up for the inceased efficiency of the Phenom architecture, so you won't notice any performance increase with a low-clocked tri-core unless you multitask.
I personally, however, would wait... your current CPU is decent (not great, but not bad either). If you really want to upgrade, look into the 3GHz+ Athlon X2s that come with 2MB(2x1) of L2 cache, extra clockspeed alone won't give as much extra performance gains as you'd want, or you could browse for the AMD tri-cores and see if you can find any 2.4GHz+ B3+ stepping CPUs at a decent price point (I'm no good at converting currencies, but about 65-70 pounds would probably be around the max I would pay). However, as I said, I would wait and save up for a good intel build or maybe wait for the new 45nm Phenoms, they are clocked way higher than current Phenoms and have numerous improvements implemented in silicon, so those things may actually turn out to be good...who knows. Probably all current AMD CPUs will struggle with Crysis, some like the 3.2GHz Athlons with 2MB cache may do the job, but for Crysis, considering the performance of current AMD CPUs, I would get an intel build or wait for AMD to come up with something better.
BTW, If you've read this far, you deserve a prize *hands over a chocolate cookie*
