Advice on quickest base unit for around £200-250 new or used.
andyleem
Hello
I need a new base unit for work. It needs to be as quick as possible, preferrably 3GHZ+ processor and 2GB RAM upwards. I have had a look on eBay and just want to know what kind of ones i should be looking for etc. Should i get a quad core one?
Here are some i have found...
http://cgi.ebay.co.uk/XBLADE-AMD-54...=39:1|66:2|65:3|240:1318&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/STUNNING-5-6-...=39:1|66:2|65:3|240:1318&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/NEW-INTEL-PEN...=39:1|66:2|65:3|240:1318&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/Dell-VOSTRO-2...=39:1|66:2|65:3|240:1318&_trksid=p3286.c0.m14
Thanks!
Their posted processor speeds make me a little nervous (first two)... Especially with that low of a cost.
As for quad core, if you plan on multitasking a lot it's recommended that you do. You also probably won't need 3+GHz.
well its an auction so they are the starting price's thats why they are so low!
think the best bet would be the 1st one especialy with your budget
