dont go acrylic, here are a few reasons why:
- the side panels do not slide off like a normal case, they must be unscrewed the whole way around (usually 8-20 screws)
- once the side panel is off, the case is extremely wobbly since the side panels are the bulk of the frame
- there is nowhere to hide cables, its almost impossible to make it look good
- they scratch everything they touch, and everything they touch scratches them
- most of them only use 80mm fans, which means to get proper cooling it will be LOUD
- dust ftl
