sokol
I used Plastikote on mine, I did about 10 coats in total I think... I also have the Antec 900.
This is how it came out;
Looks nice are you gonna put a finishing gloss coat on it.
http://www.amazon.com/Campbell-Haus...ref=sr_1_1?ie=UTF8&s=hi&qid=1223046857&sr=1-1
That one seems popular on amazon... I'll check other places. You could probaly rent one from a hardware store or something as well.
Nope, I wanted a matt finish to it, so I'm going to leave it as it is.
Looks great, on my next build I will custom paint my case.
Check that like or go to Home Depot or Lowes and check their sand blasters, You dont need a big one that atentora provided is great, just make sure it has power.
well you will need to look for paint that says it will work with aluminum (or whatever your case in made out of.
Most cases are aluminum, some are steel.
