aalexander
Hi,
I'm going to be purchasing a laptop soon, and am interested in getting some guidance. I'm not necessarily looking for recommendations on specific models (although all input is welcome) more for general recommendations on what sort of features and specifications I should look for.
I travel quite a bit, both US and internationally. What I'm looking for is something to do general Internet surfing, run skype to communicate with folks back home, play the occasional movie on DVD, display (and occasionally edit) PowerPoint presentations, do some limited photoshopping, read manuals in pdf format. I'm not a gamer and don't foresee becoming one.
A few things I'm wondering about, in no particular order:
What do I need to know about wireless modems? Much of my use will be via wireless in hotels, coffee shops, etc. Any potential pitfalls? Are all modems equally compatible? are there compatibility issues, say in Europe? How fast a modem should one get, or is that even an issue?
RAM: How much should I look for? I'll be working with documents and powerpoints in the 50-100Mb range. Is there a minimum amount of RAM for acceptable playing of movies from DVDs?
Optical drives: Is blu-ray compatibility fairly common? expensive/inexpensive? Seems like it would be a good thing to have, cause that appears to be the next standard for entertainment media.
Operating System? I'm so far behind the times on this, I don't even know what to ask. What do I need to know?
Non wireless Internet: Some of the places I stay have Internet available, not wireless. Comes through a wire with a plug that looks a little like a telephone plug, but larger....LAN connection? If I have one of those same type connections in the laptop, does that mean I have everything I need to tap into non-wireless Internet, or is there more to it than that?
Displays? Again don’t know much about this, are they all satisfactory for watching movies ore are there types to avoid?
Bottom line is, I’m not looking to get a top of the line, bleeding edge machine, but I don’t want to get something that doesn’t serve my purposes. Any input would be appreciated.
Thanks.
Thanks.
