Can anybody give me information about this...
lubo4444
can anybody give me information about this:
clonysoft.vistaoneclickactivator
i found it with spybot...and i cant delete it any help ?
Naughty Boy......
That is a crack for vista that has been used to activate a copy of Vista instead of buying it.
LOL
What!??!?! i dont even have windows vista i am currently using Windows XP pro...I hate vista btw ... is there a way to remove it ? funny cuz i never had Vista on this computer neither...
Ok Post a Hijackthis log
and a combofix log.
Just elaborating. ;)
Hello, please download and post a log with HiJackThis.
Click here to download HJTsetup.exe
  • Save HJTsetup.exe to your desktop.
  • Double click on the HJTsetup.exe icon on your desktop.
  • By default it will install to C:\Program Files\Hijack This.
  • Continue to click Next in the setup dialogue boxes until you get to the Select Additional Tasks dialogue.
  • Put a check by Create a desktop icon then click Next again.
  • Continue to follow the rest of the prompts from there.
  • At the final dialogue box click Finish and it will launch Hijack This.
  • Click on the Do a system scan and save a log file button. It will scan and then ask you to save the log.
  • Click Save to save the log file and then the log will open in notepad.
  • Click on "Edit > Select All" then click on "Edit > Copy" to copy the entire contents of the log.
  • Come back here to this thread and Paste the log in your next reply.
  • DO NOT have Hijack This fix anything yet. Most of what it finds will be harmless or even required.
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
Note: Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Combofix should never take more that 20 minutes including the reboot if malware is detected.
If it does, open Task Manager then Processes tab (press ctrl, alt and del at the same time) and end any processes of findstr, find, sed or swreg, then combofix should continue.
If that happened we want to know, and also what process you had to end.
Sorry guys i asked a friend who works with computers to help me with this and he came to my house and he deleted that thing.... I really appreciate the help though. 10X
That's some creative thinking. Nice man :D
Lubo already had these instructions before, that's why I didn't post the canned speech.
Canned speeches :D
