G Gordon.C Member Oct 18, 2008 #1 Hi, I am building a new PC and I am planning to reinstall my system on my old computer and then just insert the hard drive into the new PC. Does it not cause any harm to the new hardware or possibly decrease its potential performance?
D ducis Active Member Oct 18, 2008 #2 the difference an old hard drive vs a new one is certainly noticeable in some tasks
G Gordon.C Member Oct 18, 2008 #4 oscaryu1 said: You can't plug and play hard drives. Click to expand... What do you mean? Why is it an issue to run the same system on two different hardwares?
tlarkin VIP Member Oct 18, 2008 #5 Gordon.C said: What do you mean? Why is it an issue to run the same system on two different hardwares? Click to expand... Well for one Windows DRM will not like it one bit
G Gordon.C Member Oct 18, 2008 #6 tlarkin said: Well for one Windows DRM will not like it one bit Click to expand... I was talking about the hardware. If the hardware can handle it? But that is a good point. Well then I buy a new sys with my new PC no problem So does it harm the hardware or not? Last edited: Oct 19, 2008
