RAM slot not working
ok_horn
i just bought a 2gb stick of ddr2 ram.... i have 512 gb of ram in 2 slots already. they are in the following order when i put the 2gb stick in:
a. empty
b. 215 mb
c. 2 gb
d. 215 mb
i turn the computer on and it's only saying 512 still. so i rearrange them as followed:
a.215 mb
b.
c. 215 mb
d.2 gb
now it's only saying 2 gb's..... are the slots messed up or can i not arrange the ram like that?
Usually your motherboard manual will spell out how the RAM can be arranged.
You should only have an empty slot after any others are filled first.
For instance:
a. 2GB
b. 215MB (odd size... sure you don't mean 512MB? or 256MB?)
c. 215MB
d. empty slot LAST
Tom
For instance:
a. 2GB
c. 215MB
d. empty slot LAST
Tom
thanks for the reply. i have a dell computer (i know, i know).... i'll check my manual, but i thought ram was supposed to match in the 1st and 3rd slots, and the 2nd and 4th slots....sorry i meant 256 mb...
