Hey everybody. My comp has been getting a little too hot for my taste lately and I think it's time that I did something about it. I am using the "COOLER MASTER Centurion" case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
My fans:
Side: 80MM (Located at about the middle of the case, vertically speaking)
Back: 120MM (Located at about the middle of the case, vertically speaking)
Front: 80MM (Located at the very bottom of the case, vertically speaking)
Note: There is a rectangular vent(As seen in the link)below the side fan, if that helps in deciding how to get optimal airflow.
Simply, my question is:
Which direction should each of these fans be blowing to achieve optimal cooling for my case?
Thank you very much.
My fans:
