What is the best graphics card I can get?
AUTOBOOT2000
What is THE best graphics card on the market right now and link please... I don't really want to do sli/dual unless you really reccommend it... oh and also that's below 600 dollars...
Okay I pretty much narrowed it down to these...
http://www.newegg.com/Product/Produ...escription=&Ntk=&SpeTabStoreType=&srchInDesc=
I don't understand are these all the same cards but with different logos slapped on them?? ^^^ if not which one should I get which one is the highest quality?? And is there a better cheaper card I can get or is that pretty much my best choice... ps I want it to be ridiculously fast.
Scout I was looking at that one before but I will have to rob another bank if I put that in my budget. Are these all the same just diff brands or is one of them better I am getting one of these... which one??
here is what i'm thinking of so far...
motherboard- 145$
this is what I want right? comes with the sound card and everything?
http://www.ncixus.com/products/25851/P5K-E/WIFI-AP/ASUS/
CASE - 105$(I need a good case this is good I assume?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Video Card - 550$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102768
Processor - 190$(I should get this one right?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
CRAZY - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041 $319.99
Hard Drive - 160$(this is good right?)
2 of these
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148335
RAM/Memory - 85$
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231192
Power Supply - 220$
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171022
Disc Drive - 24$
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151155
