If You Had $10,000 To Spend On A Computer?
awildgoose
I am not sure what I would do, and I am sure I will eventually post, but what about you? $10,000 to spend, build whatever.
P.S. No links for parts. e.g. www.msy.com.au, newegg.com etc
Case: Thermaltake Armor Case w/ 25CM Side Fan- $169.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133021
Power Supply: ABS 1300 Watt PSU- $469.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817814011
Motherboard: ASUS P5Q-PRO ATX Motherboard- $199.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
CPU: Intel Core 2 Quad Q9650 3.0GHz- $539.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115130
CFU Fan: Zalman Heatsink and Fan- $51.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
Thermal Grease: Artic Silver 5 Thermal Grease- $5.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
2x Memory: OCZ Reaper HPC Memory DDR2 1066- $255.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
2x Hard Drive (RAID 0): Western Digital 300GB VelociRaptors- $559.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136260
Storage Drive: Western Digital RE3 WD1002FBYS 1TB Hard Drive- $209.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136313
2x Video Card (Quad Crossfire): SAPPHIRE 100251SR Radeon HD 4870 X2- $1079.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102768
Blue-Ray Burner: LG 6X Blue-ray Burner- $229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136155
Operating System: Windows Vista Ulitmate 64-Bit SP1- $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116493
63083 got it pretty good but I got some upgrades for him...
also that quad crossfire setup would cost 2000 not 1000 that's 2 1 cards not 4 like he advertises... yes of course the x2 technically has 2 gpus...
QX9770 - $1,439.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115051&Tpk=QX9770
Rather raid 0 I would do Raid 0+1 so i'm upping the 2 x hard drives to 4 of them. Why not we have 10,000 free dollars? ~1,100$
also if you want to do 4 way sli you need this board
ASUS P5E64 WS EVOLUTION LGA 775 Intel X48 ATX Intel Motherboard - $329.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131300
in which case you would want better ram...
2*SUPER TALENT 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820609274
Hey guys, didn't I say no links to websites?
Please just post what you would get, I'm still deciding by the way
Yeh I most likely should.
It's a cool thread idea, and naturally everyone just starts linking their dream cart.
I would definitely hook up some silent water cooling in a mac pro, 32gb fully buffered ram, 2 quad xeon processors... wait the budget was $10,000? I think I passed that :(
I would definitely hook up some silent water cooling in a mac pro, 32gb fully buffered ram, 2 quad xeon processors... wait the budget was $10,000? I think I passed thatt :(
You passed that, beh who cares, I don't, I haven't even put down what I would get and I'm the thread starter.
Case : COOLER MASTER Stacker 830 NVIDIA Edition for $260
PSU : Thermaltake Toughpower 1200W for $370
Motherboard : EVGA nForce 790i for $320
CPU : Intel Core 2 Extreme QX9650 for $1000
RAM : Patriot Viper 4GB (2 x 2GB) DDR3 2000 MHz (PC3 16000) for $345
Graphics Cards : 2 X EVGA GTX 280 SSC Edition for $1000
Hard Drive : Western Digital VelociRaptor 300GB for $280
Screen : SAMSUNG Rose-Black 24" HDTV for $470
It's a good start....it will take extra time to figure out the rest:)
if you wanted to use the 10k, you would do a skulltrail equivalent of nehalem, and use 3 gtx 280's, two the the extreme nehalems, a pair of vapor phase change units for processors, then a water chiller for the video cards
^ I think that's more than enough for an excellent gaming machine. I'd save the other $9,000 for future upgrades ;)
If I had $10,000 for a computer I would build this and then do 1 of two things after. Prices in AUS from www.msy.com.au and www.wowiwcked.com.au (I haven't counted, so I most likely went way over).
Motherboard: EP45-Extreme $332
HDD : Samsung SATA 1T $159
CPU : Intel Q9650 $859
RAM : 4G kit of DDR3 $265
GPU : ASUS 1G 280GTX $599
Sound Card : D2X U.F. PCI-E $209
Moniter : LG 50" 100HZ PLASMA TV WITH HD $1,988
PSU : Thermaltake ToughPower 1500W $448
Case : Thermaltake Armour +MX $148
I think that is a bit more than $10,000 but I don't care.
After I have bought myself that I would:
A: Keep it and brag to my friends and be annoying or
B: Sell it and get myself a new motobike, TTR-225.
Dude your only at like 5 k... i like what you built.. but i'd go for a 32inch... 50 in is HUGE.. I have a 52... the only time i hook up to it, is when i'm watch a HD movie from my PC... BTW I have the Samsung 52in Touch of Color... something like that... IT ROCKS!!!...
O BTW i'd take like the MIS P7N and go Crossfire X with 2 48070X2's.... THAT IS CRAZY....
I was only at 5K?! Dam I could go a lot more than ay? Maybe run dual screen 50in, OH YEAH!
i would buy a Dell lol kidding kidding id prob go mad with power then just hand it over to my tame Computer guy to sort it out
