BluEagle91
Hello everybody,
I am new on this forum, so i hope this is the right place to write about my problem.
I have an Gigabyte GA-MA69VM-S2 motherboard, this motherboard have the feature that can boot form any possible device. In my PC i have to, CD/DVD units, LG standard DVD reader and CD-RW, and PLEXTOR DVD-RW model PX - 708A. Of course FDD.
Everything is working perfectly, but when i turn on my computer, or from some reason restart it, when it try to boot from CD/DVD, and there is no bootable CD/DVD inside it reports NTLDR is missing Press CTRL - ALT - DEL to restart.
Now when i put some bootable CD/DVD inside let say Windows Vista Ultimate installation DVD, it display message to boot from DVD, and when pass those 5 seconds you have to press any key to start setup, computer continues to boot from HDD and start Windows. Today i started my PC, with Vista Ultimate Setup DVD inside, and it started Vista Setup, i did not press any key, keyboard is fine, no locked keys if you understand me.
I tried to change boot priority, but if CD ROM is not number one for boot, the computer wont start just display message NTLDR is missing.
However i did not tried changing jumper configuration on my CD/DVD units, but they are cable select both.
I was fighting with this for couple of months, and i lost any ideas. Can anybody help me?
O, yes i have installed Windows XP pro SP3 and Windows Vista Ultimate SP1 on my PC. When i pass the booting sequence with DVD everything is workin perfectly both OS.
Thanks.
Thanks.
