Video file problem
MightyKing
I did not find a suitable place for this thread, but I hope people will respond.
I recorded a video file using a screen recorder program. A few days ago, the file worked perfectly (.avi) i could see it and all. Somehow now... the file is just 0kb in size... what can I do to restore that file?
I did do a Restore Point on my computer because of some program error non-related to this issue, but just wondering if that could have affected the video file.
Nope. It should still be saved to wherever you saved it to without a problem.
Ok, well then how come now the video file is simply 0kb in size?? that was not like that a couple of days ago... how do i fix the avi?
Thats odd, iv had that happen when downloading things.
Maybe the file moved and that was a temp file, search your HD for it and see what you get. If not, there's almost nothing you can do feasibly.
Haya is the program you downloaded to record a trail verison if so the program may have deleted it because of that fact
I have full version of BSR Screen Recorder 4. After youre recording, you click on the stop button it will automatically save to default directory... but somehow the video file out of nowhere got corrupted I guess and its size turned to 0kb
