dannaswolcott
I have set the domain policy to lock out accounts after 3 invalid login attempts. Well for some reason it does not work. Can anyone help me get account lockout working? Thanks in advance!
are you sure that the policy is being pushed? you can do gpupdate /force to force a update
Ok, then what pollicy are you putting it as. It you made your own pollicy that is linked to a OU, then you need to create a sub OU and call it computers. Then go over the the computers OU (not the subfolder) and drag all the ones you want to be effected to the new OU. Then it should work
What do you mean by OU?
