Intel PROset Wireless 3945abg and WPA
JAFL
Does anyone know which router brands are most compatible with the Intel PROset Wireless 3945abg adapter? Specifically for using WPA?
I'm using a D-link 615 (which supports WEP, WPA, WPA2), but it will only connect to my Intel PRO using WEP, WPA won't work. And I have xp sp2, so I should have the wpa patch.
I'm considering purchasing a different adapter card.
Have the most recent drivers for it?
I wondered the same thing. But after updating the drivers, the driver no longer works, so I have to use the windows wifi utility to connect with WEP.
I found the proset wireless 3945 specs online and it does support WPA. So I don't think that's the issue.
