Can't get inside 2wire modem/router
meg
As the subject says, I can no longer type in my default gateway (and I've tried many other known ip's for 2wire routers) and get inside my 2wire modem/router.
The default ip for this 2wire has always worked, because I would constantly go into it to port forward. So I don't have the wrong numbers, that I'm sure of. This has been going on a few months, but I never really cared because I had all my most used programs ports' forwarded already.
BUT! I just had the dreadful reformat from Vista back to XP and I cannot get into the router and forward my precious ports.
Why would the numbers just stop working? Does this happen often? If anyone thinks it's best I just call my isp, then sigh... I will do that!
Thanks.
Oh and hi! I'm new.
im guessing it worked? lol
Yes... I just need to learn to google properly because all the stuff I came up with was "I can't connect to my internet on a 2wire! help!"
thank youuu, oh and why exactly is it that an old default gateway IP doesn't work anymore when it used to? If you know..
I dont know that, sorry, thats just the first thing i found when i googled it lol. try searching google a bit more, you might find an answer.
The Old Default Gateway you're thinking of is prob 172.16.0.1
Your firmware probably updated that's why you're on the new scheme.
