Folding question
Bliepo
Well, allright. I have installed this folding program, which 'helps mankind' by doing certain simulations. I am running it now, but have some questions about it.
1. Does it autodelete old files which aren't needed anymore?
2. If not, can I delete them, and how?
it doesnt download any files onto your system...
it just processes information and sends it back to whoever you're folding for
theres nothing to delete :D
Actually, the work packets are files; some are larger than 10MB, depending on the client. To answer your question, once a worker unit is complete, the previous worker unit files are overwritten with the new files, so you don't need to manually delete anything.
really? i wasn't aware of that
is there a way to manually set the maximum space that F@H can utilize?
You can tell the client to download smaller packets, but you don't really need to. Both my SMP and GPU client directories take up a total of 70MB. Most of that is various DLL and operating files needed for the client to run, not the Work packets.
