My first ever budget gaming build!!
delirium
after doing research here, and asking numerous questions I have finally decided on this build for a budget gaming pc:
graphics
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130339
power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139001
processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
keyboard/mouse
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126174
memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186148
sound card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102002
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
cd/dvd drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135176
Total: 736.90
my questions are:
is everything compatible with each other?
the graphics card I have chosen is out of stock, can you find me a similar one that is compatible with my mobo?
do you recommend any changes?
Thank you all for all of your never ending help.
case:
i'd get a antec 300, better airflow same quality. all depends on your taste though. If you take this you can combine it with your psu to get 30 bucks off. you can take this psu
Sound card:
throw it out, to really have an improvement on onboard sound nowadays you need to spend over 80 bucks
graphics:
about the same is an 4850http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
hard disk:
take a look at this one, more capacity same price
cpu:
go for the e8400
This list comes out a little bit higher than yours but it's really worth your while
edit: 2048megabytes beat me to the punch :P his psu is fine to.
cool thanks!!
two more questions
what will i need to buy to connect to the internet wirelessly since i wont be able to but my comp near our router?
and
What is the best vista version to use for gaming?
cool thanks!!
two more questions
and
You need a wireless network adapter here's one off newegg. Maybe you want cheaper one that's your choice obviously just giving you an idea of what you need this one is very good though
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124183
As far as vista goes, 64-bit vista home premium will do just fine..
