Disk space problems, need help.
Does it list what it deletes? I don't like a program just deleting stuff off my comp, I would rather i do it that way nothing gets botched in the process.
Trust him, he helped me. I used SD Fix and Combo Fix, and they do have log files to tell you what they deleted. It wont just delete any old file only fishy stuff that's been identified as harmful.
Trust him, he helped me. I used SD Fix and Combo Fix, and they do have log files to tell you what they deleted. It wont just delete any old file only fishy stuff.
I don't trust anyone but myself when it comes to IT and Computers, or perhaps someone I actually know and have worked with. seen too many "experts" jack things up in the past.
No it doesn't display a list or a log.
However all it does is empty the TEMP folders and files in use will be left alone.
I would have to look at the app before I would recommend it to anyone. I think maybe writing a script to just clean them would be best. I don't really batch or script much for windows maybe something new and fun to learn.
