B billozz Member Nov 22, 2008 #1 i have a laptop with a built in webcam is there any way to disable it and use an external cam plugged into usb port thanks bill
jjsevdt New Member Nov 25, 2008 #2 You can use an external without disabling it, but if you go into your device manager you can disable it that way.
C camel lips New Member Nov 25, 2008 #3 billozz said: i have a laptop with a built in webcam is there any way to disable it and use an external cam plugged into usb port thanks bill Click to expand... Sure >start..right click my computer>left click manage>left click device manager>left click imaging devices>left click device>click disable Then plug in your new webcam,restart the computer and let it detect and install the driver.
