Jozeorules
banned
I ordered a radeon 4670, it arrived 2 minutes ago. I would like any advice of any sort. How hard is it to install? How will it run on a 300W? Does DVI look alot better than VGA? What problems might i encounter? Any feedback please
I ordered a radeon 4670, it arrived 2 minutes ago. I would like any advice of any sort. How hard is it to install? How will it run on a 300W? Does DVI look alot better than VGA? What problems might i encounter? Any feedback please![]()
I installed the card, works fine.. although the DVI cable wont go into the back of my monitor (Monitors fault) So im using a dvi-vga adaptor![]()
