Ugrade or add one more hard drive
lulumara
Hi, I did add one more Hard drive(WD SATA 500Gb) to my Dell 5150 my old hard drive had 160Gb , just that when i open my computer it doesn't show the other hard drive(500GB) I just connect only one connection that is hanging below the bay . what's wrong with it any thing did I miss I was looking other connection but I cannot see any other cable at all? There are two cable or line connection in the primary drive one small and other little wider in length.Any help is appreciated thanks in advance.:confused:
A Sata drive requires 2 connections. One for power, one for data. The wider flat cable is for power, the smaller one for data. If you don't have an extra power cable from the power supply then you will need a molex to sata power converter plug, which is sold at most computer stores. You can also try going into disk management and see if its listed there and there was just no drive letter assigned to it. Do this by right clicking on "my computer" and click on manage, click on disk management on the left and see what is listed.
I did connect the wide flat cable to sata drive can't find any small cable for data? This hard drive suppose to be secondary hard drive not primary as I said before. I'm using Window XP media edition when I click my computer no disk management that I seen where's that?Thanks again. Any other way so to see my other hard rive and to work also.
Does your motherboard have another SATA port available? Follow the data cable from your original drive to the motherboard and see if there is another port near one used for the original drive. What computer do you have? Store bought(HP,Dell,Gateway?) or custom build? Do you have a model number for us to look up to see if it can handle another hard drive?
By the way, SATA drives are not configured as Master or Slave per say like the older IDE drives are jumpered for that. One drive per SATA cable and first boot is configured in the bios.
Not sure for the model, Dell 5150,bought it in dell not custom built,i checked my manual on internet doesn't have any SATA port looks like I'm in trouble but I will open the computer before returning the 500GB look for the port,thanks again.
Yes there's a SATA port beside the old SATA port is that right? A rectangular shape the same port of SATA port. Your super teacher men Big thanks again.I will buy the cable for it. So you telling me that it will automatically recognize the drive means no primary and seconhdary as in IDE right?
Correct, HOWEVER, you might have to go into the bios to activate the second port. Dell is famous for being able to activate or deactivate individual SATA ports.
How do I go to bios ,means restaring and hit F1 is that right I did checked my other computer and it had an extra small cable for data so I connect the cable but doesn't recognize that there's an additional hard drive at all.
I did restart my computer and do the bios setup and activate the second hard drive then save and exit on it yap it had recognized that there's a hard drive (Device Manager) but when I go to my computer there's only one hard drive how can I show two hard drive so I can use the other one also?
Right click on my computer icon, click on manage, click on device management and see if your new hard drive is listed but without a driver letter assisgned to it. If thats the case then you just have to assign it a drive letter.
I did my computer rt click but cannot see any management? Anything that i can do any other way to assign the drive for mynew hard drive? Thanks Johnb35.
When you right click on "my computer" icon, you should see a list of items, one of them will be "manage", click it. When the page opens click on disk management on the left hand side.
Hey Johnb35 thank you very much for the helped I on the go right now I got it and name it drive F. Cheers!!! And thanks also to laznz1 for comment . This site really rocks!!!
