ACronis True Image
PcGk
I use this software to image my HDD. I use incremental backups and right now I have a ton of files occupying space. For example the first backup was 20gb, then each incremental backup after that was 22gb, 24,gb etc etc. and they are listed as backup1, backup2, and so on. Can I delete all the old backups safely or do I need them to properly use the incremental backup method? Thanks.
Yes, you can safely delete the old backups. Your most recent backup will still be intact, and the incremental method will proceed normally.
i also use and found this very useful. that was the 1st thing i did is put it to the test with a low level format. dam thing will even get your usb working from dos. since your doing the backups so often ya might want to keep at least the last two backups in case one gets corrupted.
