My first build should i go for Water cooling or Fan Cooling?
FairDoos
The title really says it all but anyway. This is my first build should i go with water cooling or Fan cooling i know fan cooling is easier? but water cooling is better? But anyway its my first build thanks!:D
are you going to be overclocking, and are you going to be doing a custom build on the watercooling, or buy a kit, if you're thinking about buying a kit, don't do it, as most are crap compared to air cooling
Im not going to be overclocking no i just want to get to grips with how to build a computer first but i was thinkig on second build maye putting watercooling in but then i thought why not just try it on first build? Ive not really looked into water cooling as such yet because it dint come acrss to me for a first build util now so should i just stick wih fan? would be more simple wouldnt it?:)
ya dude im on my first build and going w/ WC because i plan and want to OC as much as i possible can while still keeping decent temps, but if u dont plan on doing any OCing at all just get a heatsink
i dunno i pretty much just destroyed the computer lol, it was a cartridge type socket so i have no real idea, currently working on turning the actual cpu into a keychain, just have to get the rest of the solder off to make it safe, and delid the processor oh, and it took 1.9v to reach stock speeds lol
i dont know if i own anything that is 8mb, dude you are old school. can you try to run crysis on that beast for me. a 500mhz keychain, nice
Ah! Google says it's supposed to be 1.3GHz. Anyway, I should rip the remaining pins off my old Sempron and turn it into a magnet or something...
I found an old Celeron and a motherboard in my basement, the Celeron is clocked at 500 mhz lol, and the FSB of the motherboard doesn't even have any cooling, it also only has PCI slots :P.
EDIT: It also has a Mitsubishi 3V lithium battery lol...
and the fan cooling is going to be a ton cheaper, im kind of scared what the final price of my WC kit is going to cost, 1 cpu, 2-3 GPUs and a chipset. but thats down the road, im going to start w/ my cpu and 1 gpu.
