Hi Everyone, it's been months since I was last on, in that time many bad things have happened, 2 deaths, Job changes and many other things have taken all of my time. I even lost touch with what was going on in the puter world. Reality sucks! I have NO idea what the current good cpu's vs bang for buck are, or what motherboards are doing today. And since I remember my days of discussing systems with you all, this is the only place I would come to for advice. It.s been just a few days over a year since the last system I built. And that was for someone else. My current system is ancient. With a AMD x2 4200 and a AGP ati 2600 GPU, I am way over due for a new system.
Now let me get to my question. I am in desperate need for a new system. I have $1500 to spend. I do not need a monitor since I will be re using my 21 inch flat screen. But I need everything else including a case. As much as I hated using the antec 900 in my stepsons build a year ago, I am really considering using one for this build, but heavily modding it for my taste, including getting rid of the stock fans for much quieter ones.
Now, unless someone has a better case in mind I will be using that Antec, but otherwise I need everything.
Power supplys, If I decide to use the antec, then I would insist on a modular design PSU.
New hard drives with at least 300 gigs I don't really want to run a raid array, but I might. I do want fast drives though. 2 Drives needed. I might go for a 150 gig raptor for my OS and programs with a 300 gig or better for files
Maybe a blue ray burner, but I can always get one of those later when the prices for them crash. I can even re task my current dvd burner, but they are so cheap I might as well get a new one.
I will need this to be able to run Crysis at a decent frame rate and do some video and picture editing. But it really does not need to be uber fast, just fast enough. Dual GPU cards are going to be considered, but not required. I am kind of leaning torward ATI, but I will leave that up to you guys to convince me. I really like the sound of the 4870 but I have no idea what the best manufacture is.
Cpu. No idea at all what the best ones are right now, AMD? Intel? I want one that is not only fast, but one that will work with a motherboard that will not need to be replaced for at least 2 years. i7?
Motherboards, well thats where I am really behind the times. I want one that supports esata, since I have built a custom hutch for my desk that has USB ports and a dvd drive built in. And it also was built with my monitor in mind, so it is also built into the hutch. I would like the esata instead of the usb adaptor I am using for my current dvd burner. SLI? Crossfire? What I am most lost on are the new chipsets being used. Sheesh, take a few months off and everything has passed me by.
As much as I used to be into this I am ashamed to be so out of it. So please have pity on me and give me some advice. I will be taking everyone's advice and doing some research on the items you recommend, so I do not need links for prices, just names and model numbers please. Most likely I will be buying from newegg.
So if you decide to have pity on me, list your favorite current builds that will run around $1500. And please give your reason why you picked what you did. Thanks in advance.
Oh, by the way, I will be using XP pro for an operating system. I still can not get behind vista, especially with the new OS coming out soon. Yes I know that limits my ram amount, but so be it. I can always add more when that time comes. DX 10+ cards are still wanted ( and yes I know XP can't use it. But I am sure I will upgrade to the new version of windows when it comes out. After all, it's only a few months away,hopefully! )
See ya around!
See ya around!
