Is this trustable
Never heard of Easypix but this one is probably better because their in the UK instead of in China, so the quality should be better.
I'm leaning towards this one more too since its seems alittle more trusted. Also the only prob I have is this:
Operates via included batteries or via 5V USB Adapter (not included)
Whats a 5v USB Adapter does that mean when you plug the camera in the computer it charges
It means that it charges when you plug it into your pc but you can get a plug with a USB port on it that gives out a USB voltage (5v) for use to charge things.
^^^actually, scratch that. It doesn't charge as it uses 4 AA batteries so you would need to keep changing them, but if you plugged it into one of those USB power plugs it would power but not charge it.
