What Nvidia Graphics card is this?
theres 5
1. 3008
2. N122
3. barcode and Rev A03
4. barcode and *4H711057UWXZ1* 630-7876/630T0002
5. FCCE Nvidia corporation Model no.: P345 EMC no.: 2122
PCI-E Graphics card/p345 NVA-62310345-0000 (8) NVIDIA Corporation NVIDIA CORPORATION
What converter plug? :confused: You know if you plug that card into you system, you will know straight away either from POST or in windows when the windows generic driver gets installed.
What converter plug? You know if you plug that card into you system, you will know straight away either from POST or in windows when the windows generic driver gets installed.
Yeah, if you put it in your computer, you can find out that way, it's easier.
If you want to do it the hard way, you can take the heatsink off, clean the thermal paste off the GPU and the code for the chip should be there, then all you have to do is google it, but why do that when you can just plug it into you system?
