shoehorned
The size on these things are just amazing for the type of support they give. What is a good mini ITX mobo and which ones should I avoid?
You really didn't include much of anything in your post, which may be a reason there hasn't been a response.
There are far too many mini-ITX boards to just go and recommend just any without knowing what you want to do with it and how powerful you need it to be.
There's mini-ITX boards that take C2D's/775 cpu's, AM2's, or even have integrated solutions like the Atom's/dual core atoms, and VIA cpu's. Some have pci-e, while others have just pci. Some take one dimm, others two. You really need to give more info for a respectable response to be given. Just because no one's responded, doesn't mean "no one here knows anything about awkward form factors".
Thank you for the detailed answer. Extra features on mini-ITX is useless IMO. only 2 sata ports are needed (1 HD and 1 optical). RAID is definitely not needed because no one will get these kind of mobos for performance RAID. It probably won't scale well with extra HD's anyways. Also no need for a gigabit LAN port
So that Zotac mobo will be good for an HTPC right? It's small and compact, and has all the connections needed to build one.
