Really Really Tired Of This Crap
My latest problem is with my MP3 player. Bought a new player and downloaded MusicMatch. Always used this in the past and had good luck with it. Well so much for that. I downloaded it and and everything was working smooth. The first time. Now when I click on it it does nothing. Did a search and now i'm told this is a common problem with MusicMatch. It will work the very first time but not work after that. Gee aren't these computers a great wonder? Now I suppose i'll have to delete it and come up with something else. But my guess is there will be some "glitch" that I will have to deal with. Computers are like the interstate highway system. Great idea but there always working on them so you are always slowing down for the road work for the next 20 miles.
yeh but it makes life way easyer if you dont like computers dont use em lol
get windows media player or reinstall music match, theres always a solution to your problem you just gotta look for it
TOLD you there would be a glitch! I got Windows Media Player and I download and bought 3 songs from Amazon.com and it only sent one song to the Media Player. Where are the other two? Heck who knows. Reinstalled MusicMatch and all 3 songs were sent there. No problem. Well the samething happened again. When you click on it it does nothing. So i'm no better off than I was before. Also I tried to uninstall MusicMatch and it say's it can't because the program is running. But the program isn't running. Crap.
what mp3 player is it?
does your mp3 player come up in My Computer? can you view the contents that are on it from there? because some mp3 player,well actually,most (that ive come across) can be viewed as a mass storage device and you dont need any special program to transfer music to and from it...just open the window and drag songs over...the known exceptions to this are the ipod and zune which both have their own software.
why are you using music match?
if its just being used as a program to download purchased songs i would recommend replacing it with something that works better. you could download the zune program,does not require a zune to use it. it has its own marketplace which i have used for a long time,it works perfectly,and the selection is as good as any other. One thing about using the zune program and marketplace is that it uses points to represent money, 400 points is $5.00...most individual songs are 79 points (or about $1), and full albums can range from 600 points to 800 points.
I have the SanDisk Express
The reason I was using MusicMatch it was easy to find the MP3 downloads from Amazon and was easy to transfer to my mp3 player. Windows Media Player could only find one of the three songs that I bought. Why I don't know. No matter where I looked it did not find the other 2 downloads. So for right now I'm not going to buy anything more from Amazon. I will admit my wife has a IPod and she has no trouble buying&downloading songs from ITunes. I just can't figure out why my downloads went to MusicMatch but not to WMP. If I open up a Zune account can I use my SanDisk there? I don't want to pay a monthly bill,I just want to purchase songs as I go. Thanks!
That is weird. I've never used amazon though so im afraid i cant be of much help in that area. As for the zune program the account itself is free. You can buy points as you go,the increments are from 400 ($5.00) to 4000 ($50.00) with 1200 and 2000 points in between. They download to a "Zune" folder and are organized automatically by band and album name.
As far as working with your sandisk player i dont see why they wouldnt because theyre normal mp3 files. however, i have not tried it with any other player other than the zune so i cant say for sure.
