Help! Files and OS still there after formatting hard drive
spiderjames
I am trying to fix my daughter's computer that is riddled with spyware, etc... At this point when windows XP tries to open it usually just freezes up after opening. After trying unsuccessfully to run spyware/virus/adware programs to remove the offending software I tried to just reformat the C drive which is about 80G. when I go through the formatting everything appears to go as it should and shows that the drive is reformatted but after formatting nothing has changed. All the files,viruses,OS etc are still there as before the reformat. Also the computer is showing two hard drives C and D even though the computer actually has only one drive. I assume this is some sort of partition? it is not letting me reformat the D drive at all. This is an E machine (yuk) with a 1.8g processor windows XP Home edition. Any suggestions
Sounds like you didnt really format, just installed 2 copies. When you boot to the CD, Delete both partition, create a new one for the whole drive size, then format and install.
you cannot format the drive that the os is on while running it. you have to 1:put it into another computer and format it like that and 2: boot from disk, delete both partitions and format the drive. dont do a quick format, that kind doesnt check the stability of the disk, just writes a new TOC. do a regular one
Do your daughter a favor, just buy her a bigger hard drive, it solves all the problems.
He has a point 80GB is not very big for a HD any more and you can upgrade for very cheap through best buy or other companies
Three good places to look
bestbuy.com
newegg.com
tigerdirect.com
and if nothing else there is eBay or craiglist
it depends on what his daughter does. she doesnt need any bigger if she just surfs and things. now if she is a downloader, and from the sound of it she is, then thats when you go bigger
