Hard Drive Problem
I'm using XP pro now, switching to Vista later.
The reason you're only seeing partial HDD space is because before SP1, XP could only see 127GB. Just go under drive manager and resize your partition.
Ok, I'm updating to SP3 now, Should it apear as a 750GB as soon as i reboot? Or will i still have to go into the drive manager?
Ok SP2 is installed and it doesn't appear as 750GB so I guess i do have to re size my partition.
Yes, you have to resize it manually. I only know how to do it with GParted. I think you can do it in Windows somehow.
