To SLI or not to SLI...?
pauli
Hi all,
So what’s your opinion on this one: Say you were spending $X on a new video card(s). Do you:
A) Get 2 SLI cards for $0.5X
or
B) Get 1 beast card for $X.
Thanks…
depends, i find the only cards woth doubling up ar the 9600GT and the 3870
They are the only ones that give great performance when doubled up, and actually make the money spent, worth it.
But yeah, i would get a ATI 4870, kills all NVidias in the same Price range
And you can keep your intel board, and you can CF later
^^ You can only CF if his/her mobo supports CF. If he asks it's SLi then best bet is that it won't support CF.
hhmm well i personaly perfer to get the SLI but then you spend more mony buying two gpus or you wasted the mony to buy SLI... doesent realy double your graphics but its nice to have... another thing is the ability to run 2+ gpus simultaniosly psu and all... and if yoru not doing anything stressful like gaming or vidio editing then its jsut a wast of mony hope i helped:)
six month old thread!
