thenetworker
Hey.I currently have a computer (call it the master) which is connected directly to the internet. From this computer I have used ICS (internet connection Sharing) to share the internet conection from the master computer computer with my second computer. Note that this is a direct connection with ethernet ports (i.e. without a router/bus)
I was just wondering, I also have an X-box 360 which I also want to use the internet with. If I install another network card with the master computer, and then connect this port it under ICS with the X-box, will it work?
i.e. The master computer will now have two network cards, one by which shares the internet connect with my second computer. The other shares the internet connection with the x-box.
My questions now are:
1) Will this work
2) Are there any disadvantages of doing this (slow computer, internet etc)
Thanks in advance
P.S. sorry about the sketchy explanation.
1) Will this work
Thanks in advance
