Please help, mep or thermal, or anyone
DarkTears
banned
I see mep and thermal are online so i had to put them in so they would see. I have earned their respect and would appreciate their input.
First of all i need to purchase this within the next 3 hours. I just need to know if this stuff works together. and if i should get a ssd or something for the OS. and if i should get multiple Hdds for raid cause i will be mostly gaming (i think). And what exactly are the advantages for games and raid.
Optical
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Case
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
GPU
SAPPHIRE 100270SR Radeon HD 4850 X2 2GB 512-bit (256-bit x 2) GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102809
PSU
OCZ OCZ700MXSP 700W ATX12V V2.2 / EPS12V SLI Certified CrossFire Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018
Ram
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL9T-6GBNQ - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
Mobo
ASUS P6T Deluxe/OC Palm LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131351
This is the HDD i have right now. A 1 Terabyte drive but im wondering if i should get somethin faster just for the OS.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136317
Rosewill RTK-002 Anti-Static Wrist Strap - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16899261005
Thank you in advance
Oh, that's a nice sale for that CPU :) Original Price: $349.99 Sale Price $229.99 WOW!! lol
From a quick view it looks like that all works together
Im ok on everything but my harddrive.
I need to know what i should do. i hear ppl say like ssd and 15000 rpm drives are better and to install the OS on them to make programs run faster.
Is this true? and what about raid?
SSD aren't worth the price yet, you could get a 10k RPM, it would make a bit of a difference and their prices are decent. I just go for maximum space but if you don't need a ton of space then a 10,000 RPM hdd would help with load times.
You could get two of the same drive and throw them in raid 0 it will boost performance a bit.
Looks like a good build.
Like the graphics card I have dual 4850's but what your getting is that on a single card.
All the parts look great man. Great choice on the gfx card as well. Those can be oc'd and give performance almost par to 4870x2. Also for the case I would go with this http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
And you dont need and SSD right now but down the road you could always buy one, especially when they improve the technology.
I changed the RAM to this
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145222
not sure if it makes a difference.
Hmmm i cant go with that case right now since it costs double what the antec 900 costs atm.
Whats did they add or take away though with the nine hundred 2.
Both ram are good but for the price difference go with the corsair.
It's basically a minture 1200 now. Has the same fan controllers on the front, the inside is painted black. It has the newer style cutouts on the mother board tray.
They updated it to look more like the 1200 it looks like.
Better fan controllers, dust filter, and they might have taken the front panel fire wire and replaced it with an e-sata port.
Well, what do you guys think? am i good to go?
I dont really want to put the OS and store stuff on one HDD but i guess it will do for now. I can always change it later.
Im just so anxious to get this. As you can see from my sig im not working with too much right now.
