Want to help me build a custom PC for $500?
EGS
banned
Well, let's test your expertise and advice. ;)
I'm looking to build a custom PC with a budget of $500 (read below budget may be reduced to $300 depending if this deal goes through for the hard drives).
Let's see...I'm looking for a really great desktop computer.
I will game and multi-task on it for the most-part.
Requirements:
Quad-core processor or better (prefer Intel but will consider AMD)
8GB DDR2 (800mhz or faster) RAM capacity, maybe DDR3 if affordable :p
2x 10krpm 16mb cache (or greater) HDD (pending...)
Good graphics card (should support latest version of DirectX?..maybe 1GB if possible?)
Enough power and maybe a little more than I need just in case?
Well let's see what I can build!
Note, if possible, can you please include any/all cables I'll need...and LAN cards..is it possible by the way to have two LAN cards, both connected to same internet, to make internet faster? If so include it..
And also please include a good RAID controller..
Hope you guys come up with some good stuff!
Really? No cheap quad core for like $100? :(
Man I've seen some awesome builds here for like $500 and less with quad-core!! *cry*
Yeah, I'm building a very similar rig to the one in my sig with a bigger HD and 500W PSU for $430 for a music studio rig... so I doubt you'll be able to get a quad rig for that price... MAYBE if you go AMD, but I still doubt it...
$500 for a Quad-Core, 8gb, Good video card, 10k RPM HDDs? Sheesh! I'll see what I can do... Oh and, don't count on a fancy case :P Do you need an Operating System?
Oh and... between a normal HD, and a 10k RPM HD... You won't notice much of a difference... maybe a very little bit better loading time, but its not worth it.
Requirements:
If so include it..
No.
Your budget is way under what you are asking for. Also, you have a horrible attitude, lol. We are not here to serve you. We don't get paid for this. The only reason we help people like you is out of our good will.
Also, 10k hard drives isn't worth it. A person like you wouldn't notice it at all.
No.
Phew... you saved me from going off on him...
I tried man, I tried. You are way to demanding. $500 will get you a Cheap AMD Quad core, 4 GB of ram, a nice 512MB video card, and a Normal hard drive.
And plus, I really don't like your attitude, you act like you can buy anything with $500, well tough luck, build it yourself.
For your requirement, you need to have $1000.
Q8200 $170
P45 Mobo, say $100
8GB DDR2 RAM, say $80
4850 1GB, $185
HDD, $200
DVD Writer, $25
Case, say $60
PSU, say $80
OS, $100
8 gigabytes of RAM DaisyMTC? 4 gigabytes of memory is plenty. You can also get a good 500 gigabyte hard drive for less than $100. Other wise, that is a good list for a really good computer.
10k rpm hard drives was very noticeable on my server and they weren't even VelociRaptors...
I have the following situated:
Hard Drives
RAM
OS
So...all's I need is a:
Quad-Core CPU
Motherboard that can support CPU and 8GB DDR2-800mhz RAM
LAN Card (would installing two and having them both connected to same connection increase speed?)
PSU
GPU
Sound Card
Looking to spend $300-$500...whatever I can.
Thanks.
TBH i dont know how you have like 255 posts and still dont have enough or good information on what you can get with that budget. You can't really do a whole lot with that money, im not trying to be mean at all just giving you a point, but hey i maybe wrong im only a 13 yr old kid :P
i dont like his additude either, but i take this as a challenge, btw your getting linux!!!
AMD Phenom 9600 Agena 2.3GHz 109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103244
2x Kingston 4GB (2 x 2GB) 74$
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134730
2x 10000 raptor 200$
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136033
biostar motherbored 70$
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138117
case with 500 wat 50$
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156098
thats 503 bucks, with linux as a operating system thats a full system without graphics if you want a graphics card then im going to need to take off 1 of your raptors soo heres a graphics card that could go with this if you take off a harddrive
4670 1 gb graphics 94$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102804
