FairDoos
here is my budget build:
Budget build with an i7? Give me your money =]
Yes i think i ran 3dmark vantage. The disk that came with the graphics card. Is that the wrong one?
Edit: turns out i did run 3dmark vantage. i see it on my desktop.
Does it matter that i used this one?
I knew that you couldn't have scored so low on 3dmark06 when i scored 11.3k with my rig. That score looks more reasonable for a 3dmark06 score.
You sure that's right?
If it is, it makes me feel a whole load better about my rig.
It cant be right...considering what i have and what you have. Are you overclocking or something.
Im all stock here.
Overclocking your CPU to ~4GHz and a good overclock on the 4850X2 should get you into the 20K range.
I dont have water cooling or anything. I could get to 4 ghz on air?
Not if you're using stock cooling. At least I highly doubt it.
I was going to get that arctic cooler 7 thing but i think thats only for socket umm 775 or somethin
You think koronowski got that score from overclocking? his score is right on my a**. How can that be?
+1 at stock speed the 920 is still a bottle neck for your video card. You will have no problems with stock cooling to hit 3.2 to 3.4 and at that speed you prob will see a 20k result.
you overclock through the bios, unless your talking graphics cards, in which case rivatuner would be your best bet
I scored 17,208 at stock lol so you scored better than me. That was 20 x 133 but I do not have turbo on and you might. My ram was at 1066 with 9 9 9 24 timings but I could set them to 7-7-7-22 at that speed.
Try this man when you boot the computer up at the start press delete until the bios screen comes up. Go to the A.I. tweaker menu. The very first setting change it to manual. Then go down to Qpi and change it to 160. You do this by simply typing 160 in and pressing enter after. Leave everything else default. Go all the way to the right in the bios and hit enter on Save changes. The computer will reboot and if you get into windows use this program (Realtemps): http://www.techpowerup.com/downloads/1080/Real_Temp_2.60.html to check the temperature anything around 30ish at idle is good. Then make sure it is OC'd by downloading this (CPUZ):http://www.cpuid.com/cpuz.php
Ok, but before i do this what can go wrong? Like i wont fry something will I.
In cpuz my core speed is jumping all over the place. from, 1.6 to 1.9 to 2.0 to 2.8, etc. why is it jumping all over the place? and i didnt change anything yet in the bios. And should i get real temp 2.6 or 2.7?
