whick dell latitude should i get?
i would go for the D600...
ive had one and there not to bad, you also get the original windows disk with it and it has a built in wireless card!
you cant really game with it, its a very low end and old laptop but it will be fine for surfing the net.
if you want to play new games your talking a high end laptop with a good graphics card in it
okay thankyou
thats probably what ill do
thanks for the advice
I would go for the D600 aswell..
I dont know what kind of games you wish on playing, but they definitely won't be the best of quality.
Also note that the D610 doesn't have an OS, which can run you quite the bill
id probably go on addictinggames.com
but ya thanks for the advice
Which laptop should i get
hi
im lookin for a really cheap but working laptop of of amazon.com
and i was wondering if you could find one thats under $350 ive seen alot on there but i want one for gaming (addictinggames.com)
and so if you could go on amazon.com and help me out that would be awsome and if you help ill try to anwser one of your questions
oh id prefer a dell...but if you dont find any no big...
and i dont want a net book
I'm going to contradict the other guys above me - go with a D610. It's slightly lighter than the D600 and it's processor is slightly faster as well.
Personally I don't think you will be able to do a whole lot of any gaming on these computer unless you want to run some classic games on them (games that are like 5 years or older). The Mac should be straight out of the question cause of the 10 GB HDD. The D610 would be your best bet but the OS will cost some change unless you want to go with Linux but if you want to do any gaming don't. It can be done but it can be quiet a hassle. Why don't you save another 100$ and get a Acer? for only a extra 100 it would be far better i.e. dual core cpu, 2-3 times the HDD space and 2-4 times the amount of memory. And not to mention you would have a manufacture warranty.
Should i get this iBook?Great Price!!!
:confused::D:Dhttp://www.gainsaver.com/Catalog/Detail.aspx?&CCode=1015^Apple&CCode=1022^iBooks&PageIndex=0&PageMax=40&cICode=43730:o:eek::rolleyes::confused::cool::(:D:o:);):mad::P:(
