Need suggestions buying a laptop
johnson
Hi
I'm looking for 3 choices of laptops under $500 and 2 choices for laptops $500-800. The laptop would be mainly used for work and email. Thanks!
It really depends on what kind of "work" you do. What things do you do for work? (word processing, special programs you run...just give us an idea of what you are talking about)
When buying a laptop on a budget there really is two way to go about it. Bigger screen and less power or little screen and more power. Will a 15.4" screen be ok or do you need a little bigger 17" screen?
Sager notebooks are great products from a great company.
http://www.sagernotebook.com/product_customed.php?pid=144485&action=customize
Select:
-45nm Intel® Core™ 2 Duo Processor P8600 / 3MB L2 Cache, 2.40GHz, 1066MHz FSB
-Genuine MS Windows® VISTA Home Premium 32/64-Bit Edition
-250GB 7200rpm SATA 300 Hard Drive
Comes out right at $800...this will be a great laptop for basic use:)
as i said just light work like emailing
Bigger screen(17") less power
Thanks!
Select:
I would recommend a Dell Inspiron 1525, you can get one for 479$. Or if you want something smaller and just as nice I would recommend a net book like the Dell mini 9 or 12 but only if you won't need a disc drive. Mini 9 = 299$ and mini 12 = 399$. These are all base line models but nice for your needs.
