Irishwhistle
I'm trying to get VMWare Server running on my rig so I can play around with it, but every time I reboot I have to re-install it because I have DHCP... so the question is, is a static IP safe? Thanks for any help!
I don't understand your question, are they safe? Even with DHCP your client will request the same IP it has already leased over and over again until the machine is shut off or the DHCP server goes down.
Well, websites can get your IP info and if your IP doesn't change it's very easy to track, am I correct? I'm just wondering if this is a security issue.
Your isp, and the internet does not understand 192.168.x.x addresses. If your pc has a 192.168.x.x ip it can not comunicate on the internet .. thats why you have a router.
A static IP is fine .. as long as its not in the range that your dhcp server hands out.
When you go on the internet, websites see your public ip "router ip" (not 192.16 .. thats a private ip)
No one on the internet can access a 192.168.x.x unless you set your router to open ports.
