Switching Video Card
Skydog287
Video hardware error; caused windows to reboot.
Hey everyone.
I woke up this morning to it saying that windows recovered from an unexpected shutdown which it said the cause was "bluescreen". Sooo I'm guessing it's having problems because of the video card since it seem to be fine before I installed it. There is a 30 day return policy on it thanks to newegg so I think I'm going to switch it out for a different video card if problems continue...
Here is the HD 4830 Model I have now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127394
This is the comp I have btw:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113088
Here is a report on the video hardware error:
Product
Windows
Problem
Date
2/6/2009 12:04 PM
Status
Not Reported
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
Files that help describe the problem
WD-20090206-1202.dmp
sysdata.xml
Version.txt
Extra information about the problem
BCCode: 117
BCP1: FFFFFA8005A10010
BCP2: FFFFFA600461F7CC
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
And here is the report on the Shutdown Unexpectedly error:
Product
Windows
Problem
Shut down unexpectedly
Date
2/6/2009 1:42 PM
Status
Solution Available
Problem signature
Problem Event Name: BlueScreen
Locale ID: 1033
Files that help describe the problem (some files may no longer be available)
Mini020609-01.dmp
sysdata.xml
Version.txt
BCCode: 100000ea
BCP1: FFFFFA800724CBB0
BCP2: 0000000000000000
Service Pack: 1_0
Product: 768_1
Server information: 08f6fe9f-ed3e-4fc2-bc4a-b5b269bf88ae
Any ideas on what happened?
When I checked for a solution it gave me this page:
http://wer.microsoft.com/responses/....9.9?SGD=8856651e-b648-42ee-8bd8-64e0299fee6e
Thanks in advance!
Yea I changed my mind about switching cards, I want to figure out what went wrong now.
The version for CCC says it is:
Version 2008.0930.2229.38458
And when I check the driver for my video card under device manager it says:
Driver Date: 9/30/2008
Driver Version: 8.542.0.0
I should probably find an updated driver, eh?
I am not sure if this has anything to do w/ it but, you power supply is very underpowered for that card...
300 watts just won't cut it, say 70% eff. probably is something like that.
So around 210-230 watts. That card itself uses over 80watts, so that psu is on 75%+ usage all the time, not too good.
Go for a 4670, it doesn't require an extra 6 pin connector, or molex if that is what yo have. It uses half of what the 4830 uses at peak. And this is a good card too, it is equivalent to the 9600GT, but uses a lot less power, great for you computer.
So around 210-230 watts. That card itself uses over 80watts, so that psu is on 85%+ usage all the time, not too good.
oh no, I should have mentioned I replaced the power supply.
This is the PSU I currently have now:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003&Tpk=corsair 450w
