How much RAM can my motherboard support ?
ajeeb
Hi,
I have an Intel D945GCL mother board. From where can I find how much maximum DDR2 RAM does it support ?
Another thing to consider is the amount of RAM you OS supports. For instance windows Vista (32 bit) will only regonise 3GB ram max. So 8GB is a waste.
you mean 4GB, right? XP already does 3.25, so vista is not giong to be LESS. Vista supports 4GB, not 3 lol
Back to the question:
Here is the link:http://www.intel.com/products/motherboard/D945GCL/index.htm
but if you dont wanna go there, it supports up to 4GB DDR2 ram. 667 is the fastest speed.
