Crashman85
Hi all,
I installed n Asus M2N68-AM mainboard in a Compaq (HP) computer that had an Asus M2N68-LE HP-specific board. After resolving different driver issues with board CD and updates, everything seems fine.
Two questions:
I used the old heatsink/fan (for Sempron 3600+), but the fan was running full-tilt, and sounded like a jet engine. Sice it was a three-conductor fan, I couldn't use the PWM control. I decided to rig the 12V fan line to a 5V line, and it works. Starts up fine, runs about 2000RPM fairly quietly, and the CPU temp is about 36C degrees, with the MB around that. I guess that's OK?
Secondly, I'm sure if something happens that the Compaq recovery disk won't work. It'll probably tell me something like "This is not licensed to use on this computer"? So, I want to image the drive before I do anything else, and I SHOULD be able to recover to a working point from that?
Anyone use Acronis True Image? Is it reliable?
Thank you,
Crashman85
Two questions:
Thank you,
Crashman85
